- Joined
- Dec 20, 2007
- Messages
- 1
I'm using TTN6 on a Mio P550, it started running really slowly just on this application so I've copied all the files from the laptop onto the SD card & re-installed tomtom.
Everything works fine except the voices, they're all on the SD card but when I try to select any of them, I have the message that I need to either download it from tomtom.com or install it from the disk. The disk is in USA & I'm in England for a while.
Has anyone any suggestions please?
