Speed indication
GO5200
A friend has a GO5200 which shows speed limit and actual speed. My GO5200 (a few months newer I believe) does not have this feature. Is it possible to enable it or update the software?
This feature is enabled by default on roads with a known speed limit.
The speed limits are stored in the map data.
Have you updated your software and maps?
Thanks for reply. I've updated maps regularly. I believe the software is up to date, but I'll check
The MyDrive Connect website says my device is up to date
Which software version do you have?
You mean you don't have that Speed Flap?
Just tried it and everything works OK. Perhaps it was my memory, I hadn't used the TomTom for a while, as I have built-in satnav (and Android Auto).
So apologies for wasting people's time, but thanks for comments
andi.kueng
