I'm in the process of building a speed camera file for the DC Metro area. I *believe* you should be able to see what I've done so far if you go here [I had to leave off the http]:
maps.google.com/maps/ms?ie=UTF8&hl=en&om=1&z=12&msid=105760263437638273544.00000112461511e999244&msa=0
The problem is that, other than the fixed location cameras, everything else is "zones": several designated blocks where there may or may not be a temporary camera. What is the best way to designate this?
I'm also wondering if there's a good way to deal with cameras that only focus on one direction of traffic. For example, the fixed camera on 16th Street is only for Southbound travellers. Yet, the way POI's are normaly set up, you'd get the same warning even while northbound. Any suggestions?
Does anyone know how this is usually handled in the UK/Europe.
Thanks as always!
Thanks as always!
