I got a 2GB SD card for my TTOne XL-S and I am ready to set it up to use with the Tomtom. From reading posts I THINK I know what to do but I want to make sure.
Is this correct? -
Make a computer backup of the TomTom including Hidden Files. Copy that entire backup through the computer to the SD card in a card reader/writer. Insert card and turn on the TomTom.
Then -
When I do updates do I do them to the TomTom connected to the PC with the card in?
TIA!
Is this correct? -
Then -
TIA!
