This last weekend I flew from Chicago to New Jersey and took my tomtom with me, this is my first time taking my tomtom on a flight with me.
After arrival and getting into my rental car, I mounted tomtom, turned it on and waited and waited and it couldn't get a satellite fix, the map (greyed out showed me as somewhere in Illinois) and the satellite info tab showed over 10 satellite signals (greyed out too) but no fix, 10 minutes later I got desperate and tried a pin reset, waited another 10 minutes still nothing, so tried a full reset still nothing.
I kept it on, used the prepare route A-B feature to know where to go (while helpful, it's not why I got a GPS in the first place, I could have easily printed route instructions from google maps or mapquest) and got to my destination, I kept it on to see what happens, it got a fix almost an hour and a half after the last reset, that's way too excessive!!!.
When I got back to chicago, I turned it on and it took about 5 minutes to get a fix, while not instantaneous a lot better than before
I am wondering if any of you have experienced such a problem in the past, and is there a workaround or something I am missing??
