As I can't run Australia Truck on my GO720 I'm looking for a TT replacement.
Have spent numerous hours googling but witout any success.
The closest I found was a GO5100 but does not mention that it supports truck maps.
Due to the age it will have to be a second hand unit and have found a unit but the seller provides no information.
The Go5100 manual has a reference to truck """ If a truck map is not installed on this product then this product is intended for use only on cars """
Thats it.
Can anyone help.
thanks
gazza
Thats it.
Can anyone help.
thanks
gazza
