Chances are you picked up a corrupt one. The "live until" date is part of the data in one of the files, and if goofy, can prevent another from ever being loaded.Anyone know what's happened to QuickGPSfix on Tomtom Home? It's been missing for weeks, and my XL340 seems to take longer to find a signal each time its turned on.
Probably so. And no, it wouldn't even show up on the menu - but that would happen immediately following a problem with one of the files you picked up from a previous download. Once you get a 'bad' file, the date comparison (today vs.when the next download should occur) blows up, and it stops even offering them.I've had failed downloads before, but this wasn't even showing up on the menu. Anyway, it's downloading again now. Thanks.
My *.dat file on the XL340 was missing altogether. Perhaps that was the whole problem.
Easy remedy - nuke 'em all, reconnect, and you'll be good to go.
On your 340, in the root directory, you will find a folder called "ephem". That folder will contain a *.tlv file, a *.txt file, and a *.dat file. Delete all three of those files.
On your PC, in the folder My Documents/TomTom/HOME/Downloads/complete/ephemeris, you'll find a bunch of subfolders called QuickGPSfix. Delete all of those subfolders.
Hook up with Home, and you should get a new fix update.
I believe that the "Hotfix" firmware update applied ONLY to Garmin units that employed the MediaTek GPS chipset, not the SiRF III - which is why quite a number of previous Garmin models were not candidates for this update. I believe the units with STMicro chips were using something called Networks GPStream (it's been a while, so don't hold me to that name).The SIRF III did in fact support Hotfix. That's the chipset used as early as 2007 in the Garmin 7x0 series. Garmin enabled the function with a firmware update in early 2008.
