I have a couple questions for anyone out there who owns an Eclipse AVN2210p w/ TomTom PND built in. I just purchased and installed mine last weekend, but am not entirely convinced I connected the speed pulse wire correctly. I had a hard time finding any information on where exactly the wire I needed to connect it to was (I have an '03 Ford Ranger). I think I figured it out (see this link for details http://www.rangerpowersports.com/forum/showthread.php?t=218338&highlight=vss+wire) but I have no real way of testing whether or not I did it right. Unplugging the antenna while driving is out because I can't reach behind the unit when it's installed. I tried driving into my parking garage and driving around where I knew there was no signal, but once I entered the garage and turned the corner the GPS signal was lost and the map went gray and didn't move until it got a signal again. Not sure if this means the speed pulse wire isn't working correctly or not. I was hoping someone else who has the same unit could give me some insight on both whether or not I have it hooked up correctly, or an easy way to test whether or not I do.
Also, when installing the unit I noticed there was a pink wire on the wiring harness that was not mentioned anywhere on the install instructions. Literally nowhere do they say anything about it and on the pictures it isn't there. I have no idea what this wire is for so I didn't hooked it up, but I'm curious if anyone else happens to know what this extra pink wire is used for. It's on the main harness plug if that helps anyone.
Thank in advance to anyone out there who can lend a hand, I appreciate it.
