- Joined
- Sep 4, 2020
- Messages
- 33
- Country
- TomTom Model(s)
- Go Premium X
Yes, I had assumed so.
Yes - I know. I have that model, bought as an accessory, to replace the single outlet model which came with the device. The other port I use for my phone - if necessary - and that is slow to charge.
Thank you for your measured response.@John Usher
First, rest assured that any power adapter supplied with a TomTom device will be adequate to both operate and charge the device providing the device is still within normal operating parameters. That's some pretty basic engineering, and if there was a miss there, every user of your device/charger pairing would be complaining of the same thing -- and they're not.
As for worrying about whether your USB-A charger is capable of producing 2.4A or 999A, it's irrelevant. The charge current is limited on the upside by the device being charged. It draws the current that it wishes unless it's being limited by the charge source to some lower value. You needn't worry about whether the charger can produce 1.2A, 2.4A or 5A provided it's all at 5VDC. You can make the same assumption while working with your power bank experiments.
A TomTom is primarily an in-vehicle device. While it CAN be used for walking, it's impractical for that, especially given its form factor, and battery size and weight most certainly aren't increased to accommodate an extended battery-only experience. For walking, something smaller in the way of a handheld is more practical both for handling and battery life. Their screens and lack of traffic data and spoken directional prompts typically make them poor choices for in-vehicle use. Each has its purpose. Many of us own both rather than complaining about the utility of either.
As for your 85%, you need to think about what that actually means. Using the battery voltage, it is approximating that the battery is presently at about 85% of capacity. But 85% of what capacity? That of a new battery, or that of your used one that has been charged and discharged many times, in the horrible battery environment of a vehicle windscreen? If you have spent any time using a notebook/laptop device, you'll discover that capacity decreases over time in exactly the same way, but windscreen mounted devices get much more brutal treatment. The only way to "fix" that on a the more intelligent notebook/laptop devices is to run it through at test discharge/charge cycle, and then it can give you a better idea, in units of time, not % capacity, of how long you have to go on the current charge of the battery. It does this by looking at battery voltage, but considers it against a de-rated battery capacity as discovered during the test.
Welcome to the wonders of engineering power sources for mobile devices. Above was just the tip of the iceberg. We could discuss why there are times when the device must NOT be permitted to charge while you're driving around. Now you can feel free to be astounded.
That depends upon the use model. If the device is only expected to operate when there's external power available (typical for most in-vehicle use), then even if the battery has degraded to the point where it will only support unpowered operation for a couple of minutes, that's more than good enough.Basically, these devices need new batteries every 2-3 years.
