Can anyone recommend a good powered mount, preferable adjustable in length or a little longer than the standard mount, for TT 630? It would be wired directly into the fusebox. No traffic connection needed.
Thank you.
Thank you.
As far as an actualy window mount, I bought a Panavise 809-AMPS and have been completely happy with it. It hasn't come off in over a week, where the stock mount would come off every 2-3 days. It holds the unit out a bit farther than the stock mount.
It's not powered though. The OP is looking for a powered mount.
Thank you.
