Hello. My Start 40 will no longer sync with my drive. I can login into my drive ok, login into my drive connect ok too, but the gps won't login. All emails are the same and it worked fine few months ago. Did a hard reset and still not able to ' access tomtom services' with an "oops try later message" on the gps. I've tried on different computer and cables, but nothing. All software is up to date and no antivirus on.
I've got a similar-ish problem with my go 50. It however says on the gps that I'm activated and connected to all tomtom bits. But again it won't sync my new poi files on my drive. Any ideas please ? Thanks.
