Does anyone know when Tomtom will update their software so we can operate our Riders from the Tomtom Home software?
Dont give up....it is actually a great unit.
Make sure you have the latest HOME version and the latest application (7.541).
Connect to HOME, under the Help list, check on update to latest version of HOME.
It should do it automatically. It should have downloaded the emulator to operate that feature.
When you click on "operate my rider" does it show you the device and the screen is black with TomTom in the middle of it?...you then have to click on the screen.
If not, then contact support via phone, they are actually pretty helpful. Dont bother with email (total waste)..
Cheers
Ranger, that is odd, as I can set a code and plan an itinarary on my puter using HOME.
Make sure you have application 7.541 on your device, as it seems the latest 7.901 takes away that feature (at least until they fix it).
Cheers
I still can't get TT home (version: 2.4.0.104), 'Operate my Rider' itinerary function and TTR2 to comunicate with each other - very frustrating!
Pete
Just checked I have 7.901 installed on my TTR2 - but it didn't work previously with 7.541 either???
When you first clicked on "operate my rider", did a file quickly download?
I might suggest going back to the 7.541 as the feature definatly does not work on the new 7.901
Cheers
Cheers
