Not connecting to car
Go 520
I have recently come into the possession of a TomTom Go520 (not bought, but indirectly gifted, so can't go back to the original owner).
I have updated it and uploaded a European map (planning to drive abroad in the coming months) via my laptop and all went well. However, when I plug it into my car (Hyundai ix35), it fails to power up properly and summarily shuts down. I have tried changing the power lead, without effect. Has anyone else had a similar issue and, if so, what did you find to rectify it? I really don't want to have to fork out for a new sat nav right now (I know I could use my phone, but would prefer to have a dedicated sat nav in the car). Might this be a problem with the interface in the car, as opposed to the unit itself?
Many thanks in anticipation of your responses.
Did you plug the cable into the cigarette lighter charger that came with the GPS?
Or is the cable plugged directly into a USB port in the car?
A USB port, but I've ordered a cigarette lighter charger in the hope that it resolves the issue. Thanks for your reply.
A cigarette lighter charger is recommended.
The car's USB port is not powerful enough to run your GPS.
I have a BMW bought new in July 2022 and bought my current sat nav about the same time and, when I plugged it in to the cigarette lighter socket, there was no power to the sat nav. I was using the supplied charging cable so assumed this was faulty and Tom Tom sent me a replacement. To my astonishment this didn’t t work either. Upon investigation I discovered that, for reasons unknown, the cigarette lighter socket is wired differently from the norm - there’s another power take off in the boot and this worked OK so it may be worth checking this on your car.
It's not complicated to power a cigarette lighter socket.
On newer cars, a cigarette lighter socket is powered either after the ignition is switched on or after the engine is started.
Just to avoid confusion perhaps I should add that I was driving the car when I found this out. Once I found the discretely placed USB-C socket the problem was resolved. Why BMW choose to install a cigarette lighter socket with no power - with or without the engine running - is another matter.
FYI
Do you plug your GPS into a cigarette lighter charger or a USB port in your car?
A USB-A port outputs 500 mA, while a GPS requires 1200 mA to 2400 mA for newer models.
FYI
Sounds like BMW is providing USB-C ports, and there's no telling what current they're providing on those.
There are USB cable testers that can determine the power output of the USB-C port.
Furthermore, if a cigarette lighter socket is available on the BMW, you might as well use it.
Try checking it with one of these
Bodman
