From the first day that i bought subscription to TomTom Go I don't see speed cameras. I was recently on a trip to Serbia and I did see Average Speed Camera on a highway, but not so much Fixed Speed Cameras, and I don't see any here in Bosnia.
TomTom Support thinks that they just are not reported. That could be true, but it's unusual that no one had reported them. They suggested that I start reporting them, and I have no problem with that, except that I don't have that functionality on Android Auto. I was recently in a car when someone else was driving, so I used that opportunity to report one speed camera on TomTom mobile app.
Does anyone know how that reports work? Do many people need to report one single camera so that TomTom evaluate that information, and to update Speed Cameras? Or my single report is enough?
How much time is needed to see that reported camera in the Go app?
Do you see Speed Cameras when you just open the Go app and browse the map, or you need to be in navigation/routing mode to see them?
If you are not in navigation mode, but you drive with map opened, do you see cameras, and do you have warnings?
How good is TomTom cameras coverage where you live, compared to, for example, RadarBot app?
RadarBot has very accurate data here where I live, but TomTom has nothing.
Are Speed Cameras information integrated into offline map, or it works only if I'm online in that moment? So If I travel into another country where I don't have internet connection will I see Speed Cameras in the Go app after I cross the border?
I did use Mapshare web tool to report some changes on the map (one-way streets), less than month ago, and now I see that one is in status "accepted" and three are in status "fixed". So that works great. I don't know how much time is now needed to get that updated changes in offline maps. How often do we get new updated offline maps to download?
