I just noticed that all volumes are linked,
I mean, let's say i want to hear instructions via the TT, but listen to mp3's trough the fm transmitter, for sure, the volume settings will not be the same,
but if you put the volume to 100% on the MP3's it also pushes the main TT volume to 100%, wich to me is bad..
Even better example, if you set everythingg to output via FM transmitter,
there is a major difference between the Instructions level and the music level.
In order to get a good MP3's listening quality, volume should be set at around 85%, but to me getting instructions at 85% is way too loud..
I beleive that mp3 volume is one thing, and instructions volume is another.
not to forget BT phone volume..
Maybe on a next update....
unless i missed something
