Hello.
Does anyone know the altitude range or max altitude that a 910 can be operated?
The 910 has a hard drive, but I don't know what type. If the hard drive is a spin disc drive, like computer drives, it probably has a max altitude that it can be used, before damaging the unit.
If its a solid state drive, it should not affect it.
I am planning a car trip out west this spring where I will encounter altitudes of 9,000-14,000 feet.
This would not apply to airplanes, as they are pressurized.
Anyone know a safe range? Anyone used a 910 in these ranges?
Randy R.
Randy R.
