I just got the 920 and tried to use mapshare. Home says there are 20,000+ updates. When I try to download them nothing comes up. How can I view and download them. Other downloads appear ok. Thanks
You probably have to go into your preferences (on your device), and under "manage maps", enter "download free map corrections", and then the appropriate choices. I have mine set to accept 4 of the 6 choices.
You might have to check off what type of updates you want as well, in the MapShare preferences at the top of the HOME page.
