Maps for SsangYong Tivoli 2018 (X100 / X103)
I am looking for SD card content for Ssangong Tivoli 2018 model with Series X100 / X103 because my SD card got corrupt and I need to reinstall maps.
I checked here https://ssangyong.navshop.com/#/downloads for my version but it looks like Update is discontinued. I am fine, I do not want to have latest map. It is just that Map needs to be working.
The AVN version is R 3.7. See attached file.
I asked various dealers in UK, but they do not have maps of 1st get Tivoli.
Yes. I have started this thread to escalate this to Ssangyong and Tomtom (if required) because my car still have 1 year warranty left (7 years total) so they should keep old versions available to download and reinstall in such cases.
On this forum, we have no connection with SsangYong. KGM now manufactures SsangYong, so they are the ones you should contact.
TomTom only develops maps for SsangYong.
Yes, I have contacted them and shared this thread as reference. I will update the response here, once I hear something from them.
Unfortunately, support for the TomTom version present in the x100/x103 car stereo has ended. I don't know if it's possible to buy maps for this custom version of the program (perhaps 7.910) for WinCE.
Hi ;) I have a backup of old maps here, but Im having the same issue, I need the most recent maps for Tivoli X100 Europe. The version I have is Europe-1070.10927 Does anyone have a newer version?
There is no newer map available.
The manufacturer SsangYong no longer asks TomTom to release a new map version.
Yeah I understand but someone has to have a more recent version than mine. I lost my SD card and I only have this old old version. Please someone help ;)
TomTom maps are encoded to work on only one GPS device.
It should not be possible to install a downloaded map on another GPS device.
If anyone has the same car version than I have it should work.
I accidentally found the Europe 1140 for the x100 downloaded from the official site (2025) before they removed everything
Does anyone know what version of TomTom the x103 uses and what NavCore it is? Thanks!
It would be interesting to have feedback on the possibility of copying a map installed on one GPS to another GPS.
According to the moderators, it's best not to post download links here. Click on my name and choose start conversation to write me.
It says this when I try to talk to you
Hello there!
I've been browsing thoroughly and with frustration looking for a map for my Tivoli 2016 ELX and it appears that the versions available on the ssangyong site are too new.
I came across your comment when I saw you might have an older version of the maps? Currently all I get is "no map available" and i've been searching high and low for a map that works.
Hoping you could help.
andi.kueng
