Anyone using a 'custom menu' knows that you have to give up a few features (or icons) because those features are embedded within the Navcore 7 firmware. These are, "Help Me", "Safety Preferences" and "Map Corrections". I found that you can still access 'Map Corrections' under the 'Browse Map' feature.
To find the choices that are normally under 'Map Corrections' icon:
Hope this helps some of you.
- tap screen then right arrow until you see 'browse map' and tap it.
- now tap the blue cursor near the bottom
- tap 'correct location'
- You'll see all the choices to make a map correction... including 'unblock street', 'reverse traffic direction', 'edit street name', 'add POI', 'edit POI', and 'report other error' (with serveral other choices).
