There is a route I take from my house that requires a U-turn when I first get onto the street. Then it is a straight drive for some KMs, make 1 simple left turn and park the car.
If I plot this route using Shortest Route (which doesn't use IQ routing) I will get the exact route that I take with an estimated time of 18 minutes. If I plot the same route using Fastest Route with IQ routing it sends me on an extra 1.3 km route to circle back to the point where I normally make the u-turn, then it takes me on the exact same route with an estimated time of 15 minutes.
My question is simply how is it possible to take essentially the exact same route but adding an extra km or so but be 3 minutes quicker?
Another blip is that the actual time it takes with IQ routing's extra distance and turns is very close to what it estimated. However, the time it takes from the shortest route's calculation is much shorter than estimated. So I am thinking: IQ Routing may not be calculating the best routes but only gives the most accurate time estimate compared to not using IQ routing.
In other words IQ routing only looks better when comparing route times against non-IQ routes but the shortest route calculation may give better and faster routes but offer a less correct estimate of time.
Any observations by anyone who has had their device for a while and tried different routing options?
