I could nor find a mount that quite fitted my wants. So, I jerry rigged. I bought a flexable clamp on light at Lowes ($10.00). I took it apart and removed the metal light socket from the inside the plastic socket. Removed the wires. Cut out the four small plastic pieces in the inside bottom of the plastic socket, put the plastic socket back on and the metal nut and glued it all together. Took the plastic screwnut and glued a piece of plexiglass on top of it. Screwed the plastic screwnut on and then put on two pieces of velcro to make sure the mount would stay. Adjustable and works like a charm.
Hope this helps someone.
