How to load POI
Hi
Have just got my TT510 and loaded a map of Florida for when I go in a couple of weeks.Wanted to put some extra POI on it.Found the ones on this site.However not sure how to put them on.Can anyone please assist.
POPS:confused:
You would just copy it to the North_America-Map folder on the SD card for your GO510. It will automatically be selected to display under the TomTom options menu. If you want to turn off the display, just uncheck it under POI options of your TomTom menu. Even if you have it unchecked, it will still be available for searching -- it just won't display the icon on your map.
Download the POI and extract the files in the zip into your North America folder in the TomTom. Turn on your unit after this is done and go to preferences. From there go to the screen where is says diasable and enable POI. select that and you'll see your added POI there. If its not there, its not installed correctly.
Oldguy269
