- Joined
- Sep 16, 2010
- Messages
- 3
I've just bought a TomTom Start GPS and very good it is too; but I'm having a couple of frustrating problems that I can't find answers to and would be grateful if somebody could help me out.
Firstly, is there a way to get my machine to allow me to leave from my current destination (not my home)? The GPS indicates it knows where I am in the bottom left of the screen, but there doesn't seem to be a way to programme this as my departure point. For example, if I initially programme the GPS to take me from A to B, on the return trip how do I start off from B, without having to enter the address/postcode of B all over again. More importantly, say instead of wanting to leave from B, I want to depart from C, to which I don't have the postcode to hand. Isn't there a way I can tell the GPS to plan a route from C without having to enter the address/ postcode using the keyboard?
Secondly, what's with the volume? Does it always have to be turned on before every journey? Is mute the default setting? Bit annoying if it is; or is my machine not working correctly?
