Help?
I have a GO300-I'm trying to install the voices I downloaded from this site-I decompressed the files and put them in folders on my desktop.
How do I get them into the 300?
When I plug the USB into it- "Tom Tom Home" comes on and I can't navigate to my desktop. Even when I hit explore-is there supposed to be a "browse" button somewhere??
Hello and welcome.
You came to the right place for questions.
In order to get the voices into your GO, you have to connect your unit to your computer.
The easiest way is not to use home but use your windows explorer.
Go to your TomTom directory using windows explorer and located a folder that says 'Voices'
The files that you decompressed, just paste them into that file.
Disconnect your GO, and turn on your unit. Go to change voice and your GO might ask you if you only want to search English voices.....YOU MUST SELECT NO. Custom voices are considered non english. You will find the added voice some where in the list.
Good luck.
Christoffel
