Hi. I just purchased my tomtom 2 days ago, yesterday I took it to a store worked fine, I hooked it up to the TT Home to update my map. On the software, it first tried to install and failed. So I tried again and it said it downloaded and installed, but it was also alot faster than it determined. So I've looked at the map and it just shows empty land, rather than the roads it usually showed... so I zoomed out. And it says some foreign names... So I went to check the map switch and only Guam is listed.
I've tried to do a hard reset on the device itself, but the map is still gone. It keeps popping up error accessing file on device or something. Does this mean I've screwed it up or is the model defective?? I'm not sure. Please help. Much appreciated.
