Hello everyone!
I need some help. I am sorry if this subject might have been covered already. I have been checking all TomTom and GPS forums looking for solutions, but I haven't found anything that would definitely fix my issue. I just got my GPS partially working and I don't want to go back to square one.
I just finished manually installing the North America 855 map on my XL340s. I followed the instructions for a manual install provided by dhn at this link
https://www.tomtomforums.com/genera...nstall-downloaded-map-without-using-home.html
Everything went well during the file extraction and I followed the directions very carefully. I properly disconnected the unit from my computer. Once disconnected and it started to boot, the unit got stuck on the TomTom splash screen. It doesn't get any further. I tried a soft reset and that didn't work. So, I hooked my unit back up to my computer to take a look at the files and I let it connect to HOME. Under Mange my One XL, HOME told me that it had an error reading the USA_Canada_and_Mexico_P\poi.dat file.
I don't know what to do at this point. I would prefer to just manually replace that specific file with a good copy of points of interest for the 855 map. Thanks in advance.
