- Joined
- Apr 19, 2009
- Messages
- 2
I need to set up the data service between HTC Diamond and Tomtom 720. I am using a Sprint CDMA Diamond with stock rom wm 6.1. The Tomtom has installed the latest update.
I can do Internet tethering with USB and I downloaded a cab (wm6_BT_DUN) to enable the bluetooth DUN. But I am not sure if it works. Is there any way I can tell?
The Tomtom can find my Dimond has wireless data. I tried the following as manual set up in Tomtom. But they all failed. I read in another post that people can do it successfully with wm 6 on Mogul. So I guess it's a wm 6.1 or Sprint problem. Any suggestion to fix it? Thanks a lot.
Access point name: blank or Sprint PCS or Sprint PCS Vision
User name: blank or (e-mail address removed) (got it from sprint)
Password: blank or XXXXXXX (got it from sprint)
Dial number: #777
Script: blank
Dial number: #777
Script: blank
