Hi all, I am having one hell of a time trying to get this to work for the data service. When I first bought my tomtom on black Friday, I did connect it once, and it worked! Now, after the new firmware and maps it just won't
I have tried reset hole on bottom, clear flash utility, reset to factory. and still cant get it to work.
Here's whats happening, I click on tomtom traffic, it says I need to setup my wireless connection do you want to do this now? I select YES.
Then it says, please make sure your bt phone is enabled, start searching for phones now? I select YES.
Then it searches and finds mine and my wifes phone. I select mine.
Then is says searching for phone features, finds Wireless data connection, and says this phone may now be used. so I click on Continue.
Then I get an error stating "An error has occurred, unable to complete task. Do you want to set up your connection manually?"
From there I inputed the settings found on this forum, and once I select continue, my cell asks to enter the passkey, I type in 0000, and it says DUN connect with tomtom one? I select yes, and it goes to 65% and then says "Unable to set up your wireless data connection. do you want to change your settings?". Thats as far as I have been able to get. I know my phone is not on the list, but it did work before, and others here are also reporting it working. It seems like it's missing a step. I remember it asking me my carrier and type of phone before, now it don't.. do you think its broke? Thanks Tryton
