I have similar problems with my GO 910.
I have 4 car mounts (with 2 cig cables), and 2 USB cradles (with 2 AC cables).
When I first got it, I had no problem charging form any source.
About 6 months ago, I started having problems charging from the USB cradles, but holding it tightly in place with a rubber band, it worked OK. Then even that stopped working.
The 910's green light works with all (valid) combinations of mounts/cables/cradles, BUT the 910 now ONLY charges using one of the 4 car mounts (with any of the 4 cables).
I drive for 2-3 hrs most days and the battery is fully charged (via the one working car mount) at the end of the day. (The 910 battery lasts about 4 hrs in use if not plugged in, and can hold it charge without any significant loss for over a week if not in use.)
2nd Problem
About the same time, my PC stopped recognising the 910 when I "connect to computer". The PC can see a "removable drive", but without a disk. If I then remove the 910 from the USB cradle, the 910 indicates that I should put an SD card in. (The 910 has a HARD disk and no SD slot!)
However, after a reset (via paper-clip), the PC sees the 910as a "TomTom" and the auto-play triggers.
Any Ideas?
