- Joined
- Oct 10, 2025
- Messages
- 8
- Country
- TomTom Model(s)
- go 5200 wifi
hi all, I have a 5200 tomtom well I think it's a 5200 as the serial begins with zo.
issues with it are as follows:
power on and the tomtom logo appears and the progress bar gets to exactly half way then it restarts and attempts again but again it gets to half way and then displays the connect to pc picture with the small red cross
️ in between the image of the pc and tomtom device.
I power it off and power back on keeping power held and it does show the white text info screen, then
I press the power button 3 times within 1 second and the unit then shows a black screen briefly followed by the connect to pc picture with the small red cross
️ in between the image of the pc and tomtom device again, I then connect a usb cable direct to pc and to the back of the tomtom and mydrive connect automatically starts with the message restoring your device. It reaches 100% and the tomtom reboots with the progress bar going all the way across and then reboots but the progress bar gets to halfway again and the same thing happens over and over.
I've tried different cables.
I've tried the power button 3 press. 4 press as well but it's still the same outcome.
Can anyone help?
Can anyone help?
