fuzzy icon using paint
chico, ca
GO 730
OK, so i loaded an image using paint and blocked out the background in red. Problem is everytime I save the damn thing the paint program automatically kinda blends the area around the image in different shades of red which shows up a fuzz on my tt730. Is there any way to tweak the paint setting so when your done editing the pic it stays the way you save it instead of doing the blended thing. I've attached a copy of the pic so you could see what I'm talkin' about. Any help would be greatly appreciated. Thanks :D
Try saving it as a standard Windows Bitmap image or set jpeg compression to 0...the compression algorithm for the jpeg format is responsible for mucking up your colors
abstr101
