- Joined
- Aug 23, 2007
- Messages
- 9
I am online with TomTom support right now because the FM Transmitter will not consistently work. I am trying to find out if the unit is defective. Is anyone having trouble with the FM Transmitter working?
Take a look at the review here: http://www.yournav.com/content/review/356/1186057800/
Their conclusion was that the FM transmitter was virtually unusable.
Sorry.
Thanks for the link to the review. This is not what I am talking about though. I am litterally meaning that it does not work. And when it does, it will not change frequencies. I have to hit the reset button to get it to work, and once I power off and on, it will not work again until I reset again. TomTom support had me use the Clear FLash tool, which did not resolve the issue. I am going to Amazon for an exchange. Hopefully this is just a defective unit and not a hardware platform issue. I was using the new software 7.010.
Related to the review:
I DID find however, that if you uncheck the Adjust Volume According to Noise Level option, that you can turn it up to 100% and it is plenty loud on your radio. My guess is that the reveiwer did not do this.
through past experiance using an fm transmitter you never get that clear sound and you seem to always haer the static of the channel you are transmitting through.your best bet (if you have aux on your radio)is to buy a 3.5mm to rca cable and go right through your stereo.sounds great for watching movies,playing mp3s,and gps itself.i tried going through an fm transmitter with my sirius and the sound was just horrable and low.good luck
I set the 720GO to output FM and select an unused FM station (tried two different ones, one on the low end ~91, the other one ~107) ... when I select the channel, I clearly hear the test phrase "you have arrived at your destination" over the car speakers ... but when I select DONE on the 720 (at the STOP/CHANGE/DONE screen) to return to the navigation panel, the unit's onboard speaker reactivates, and there's no audio over the FM radio.
Yep, I'm having an issue with the FM transmitter as well - not a quality, issue, I just can't get it to work; posted my query re: this here:
https://www.tomtomforums.com/showthread.php?t=5087
Sounds to me as if you are cancling the previous steps and going back to the main menu as nothing ever happened.
