If you save the Mapsettings.cfg file, you can reload your favoritesFirst of all, I saved my favorites to an .OV2 category I named "Pauls_Places". I then opened an icon in TT and "saved as" to "Pauls_Places (icon has to be named same as your .ov2 file). I then modified the icon to the first letter of my name and saved it. Now on my map my POI's show up like the gas station POI icons do.
Keep in mind there are advantages to storing locations as POI's instead of favorites.
(1) You can add phone numbers to POI's
On 720:
Change Preferences > Manage POIs (screen 2) > Edit POI > Pick "Near You", "In City", etc.. For your POI category, I chose the one I made "Pauls_Places". Finally pick the POI and the next screen will give you an option to edit it and add a phone number.
(2) If you reset your TT, your POI's are not lost
