I have finally got the two items to work as expected. Hands free phone use with the address book up loaded to the 8800.
I am now also receiving traffic updates using the TT services.
My unit carrier is AT&T/Cingular. When setting up select the BB 8100 and then select the Cingular Wireless (media) not the AT&T.
I also suggest setting up the bluetooth and phone first then set up the traffic.
In the BB be sure to turn off your firewall and go to settings>options>bluetooth>menu>options and make sure that the bluetooth option Discoverable is set to "yes" then menu and save.
If the phone does not setup as you expect, in the TT's menu select phone and delete the BB8800 and start over.
Hope this helps someone else.
(e-mail address removed)
