Willy875
Moderator
- Joined
- Dec 14, 2022
- Messages
- 4,567
- Country
The Carminat built-in system is currently experiencing an issue where it displays an hourglass icon or -- : -- and fails to show the correct time.
This issue is currently affecting only Carminat systems with serial number IA.
We are aware of this issue and our team is actively investigating the cause to resolve it however, at this moment, a fix is not available. We apologise for the inconvenience caused and we appreciate your patience and understanding while we work on fixing this issue.
help.tomtom.com
Carminat TomTom isn't showing the time
If you see -- : -- instead of the time on your Carminat TomTom screen, you're experiencing a known issue that's hiding the time display.We're on it. Our team is investigating, and we expect to have...
