If I purchased from TomTom on their own supplied sd card a map of Westen & Central Europe could I copy the contents on that card to a larger sd card?
I thought the map was locked to that official SDcard and couldn't be copied to another. On Garmin's, the SD map cards can be moved from device to device. It doesn't care which model it was purchased for, but can't be copied or transferred from that original card. Does TomTom handle it differently?
