I just got a Go 740 Live. It seems to work but it constantly loops the "Busy planning a route" message on the bottom of the screen. There was a similar tread a few years back but that advice didnt work in my case.
https://www.tomtomforums.com/general-tomtom-discussion/1674-busy-planning-route-loop.html
I can stop it if I select Clear Route - obviously this is not very useful.
I have tried a soft reset (5 times) and it hasnt helped.
Any suggestions?
I'll be driving across the country on the 27th and would like to have it working by then if possible.
paul
Any suggestions?
paul
