I have searched this forum but not found a thread that seems similar to my issue, though as a newbie I could have missed something - apologies if this is a common issue and other threads exist.
I purchased a 910 while on holiday in the USA in July/August 2007 as my other satnav device failed.
I have been extremely happy with the device and it gets used relatively frequently.
However, for the past month or so I have realised that it will not turn on unless it is docked and the docking station in connected to power. This can be in the car or at home. You can press the on button for as long as you like it simply plays dead.
Plug the power into car or mains and it works properly immediately.
Unplug the power (mains or car) with the device powered up and it turns off immediately.
The battery meter is fully dark (green) which presumably means the unit thinks the battery is fully charged.
I have tried charging overnight but this does not appear to make any difference.
Not sure what else i can do. Would a reset using the button in the docking connector help (found this on this forum but just doing the 2 hour charge before attempting)
I understand the unit has a 2 year warranty but would this be a warranty issue?
