I currently own a Navigon 2100Max that has a neat feature where you can choose how many miles over the official speed limit should it generate an alert. I typically set it for 9 miles ... and that works great ... so I can do 63 on a 55 and not have to worry.
I just received the TomTom XL 340-S and all I can see is a setting for alert when you exceed the official limit. That's pretty useless.
Is there any way I can make the TomTom behave like the Navigon ? Can I edit any XML or config file to make it work like the Navigon ?
