Hi all. I would like to let you know how I fixed an apparent sticking switch on my TT940 live.
I kept getting a black screen with dos type operating system on screen when turning on and it wouldn't do anything else, I was advised via this forum that the switch was sticking on, so dismantle and resolve it that way, however a friend advised me to try WD40 first (please do not spray it all over your devise). he suggested putting a puddle of WD onto your work surface, dip a small screw driver into the puddle to administer it into the crack of the switch a little at a time. then gently keep pressing the switch till it frees up.
This worked perfectly for me my baby now works as good as new.
I hope this helps someone
