since verizon is now allowing bt dun -- has anyone configured their go 720 to use the modem from their treo700?
Yes, and after several tries I got it to work.
A) confirm you have a data plan with verizon
B) pair the TomTom with your phone bluetooth wise
C) follow the following
1. Phone selection - other
2. Carrier selection - other
3. Access point - vzw3g
4. username - (phone number)@vzw3g.com
5. password - vzw
6. number to dial - #777 (delete what this window shows on the tomtom and put the #777in)
7. No scripts
this should make the connection, test it to find weather information.
If you fail to make the traffic connection, you will have to call totom, and they will re-set your account (I had to do this). then all works fine.
If you have an unlimitted data plan, if is simply fantastic, much better than the antenna
The one sugestion I can make, is that do not let the tomtom update your route automatically to avoid traffic. I use it in Washington DC alot, and it simply goes crazy with updates at rush hour.
All i can say is that it is simply fantastic
i tried about 10 times - no luck
i can see my little "EV" try to connect - then that is it
i can get on the internet with no problem -- as i have an unlimited data plan
did you make any phone changes at all?
hmmm strange....I followed all the steps as outlined...are you able to pair up to the Tom Tom unit?
try this
5. password - vzw
7.use DHCP auto
8. DNS auto
9. No scripts left blank for logon script
