I got one of the Woot Go 510 TT's for a friend that wanted a GPS. The price was great even for a refurb @ 205 shipped. I was setting it up for him with all the latest updates and such. One thing I noticed is that the settings will not be saved, the initial ones like language, map handedness and such, if I remove and replace the chip. To be a little more specific, after putting in the chip, and going through the setup, I can turn the unit on and off repeatedly and it will not reset and I don't have to enter anything. However, if I pop the chip out and replace it, I have to go through the settings again. It seems to save the POI choices and other stuff just not the initial ones as stated above. I know when I had some problems with my TT 1 v2 I did the reflash app from the tomtom site and that fixed things. I'm wondering if this is what I need to do to the 510 or it's normally that way? I just hate to reflash if it's not needed, if something goes wrong we could end up with an expensive paperweight
Thanks,
Peaty
Thanks,
Peaty
