vent mount?
TomTom One LE
I just got a tomtom one LE and was wondering how people like the vent clip, and where can I get one.
THanks
Got mine on ebay from http://cgi3.ebay.com/ws/eBayISAPI.dll?ViewUserPage&userid=mfauls.
holds the unit nicely at a good level, easy to reach and see. Mount seems flimsy, but is not. relatively inexpensive.
A big drawback however is that it effectively makes your vent useless in cold weather as the unit sits in a stream of very hot air which is probably not good for it. I don't use the vent for heating when the tomtom is in place.
Trevorj
