TT One Will Not Power Up!
Help! My TT One will not power up at all this morning. It was working ok last night, but tonight will not do anything. Green charging light comes on when I plug it in, but I can't get it to power up anything on the screen. Can't see it in Windows Explorer either. It is less than one year old. Anyone got any suggestions?
Removed Card To Fix
It's back up. I removed the SD card and I was able to power it up. Replaced the card and everything seems fine now. This has never happened before. Anyone ever have anything similar?
Yes, I've had an incident like that too. I was away from home on a long trip, and panic set in. It was just by chance that I popped the SD card and it came to life.
Glad that it worked. The reset switch at the bottom is a soft reset though :)
kimvandenberg
