Tt 510 (tt510-tts)
Status
Not open for further replies.
Is it possible to increase sd card to 2-4 gig and install TTS to get text to speech work?
First of all TTS is a feature only to the 910 and 720. Installing it on a 510 is illegal.
To answer your question regarding the SD cards, yes you can use a 2GB or a 4GB (non-SDHC) card to use on your 510. However, if you choose to go with a 4GB SD card the two brands that work for sure are Transcend and Topram.
Status
MadmanxJim
