Traffic Camera Warning Sound
Discussion in 'TomTom Services' started by NearlyNN, Sep 12, 2009.
  1. NearlyNN
    NearlyNN
    Oct 13, 2008
    3
    The current warning sound for traffic cameras is a horn "honk honk" sound. Confusing and dangerous. Sounds like regular horn. I am used to it now, but may be missing actual horn sounds by assuming it is my TomTom warning. Not good.
    Are there any other warning sounds available that don't conflict with real sounds? Maybe an "oogah oogah", or a voice message.
    It's possible that there are options for the warning sound, but I couldn't find them.
    #1
    1. Advertisements
  2. NearlyNN
    mikealder Moderator
    Mar 23, 2009
    3,199
    Blackpool UK
    TomTom Model(s):
    720, 930, 940, XL, One 3rd
    Perhaps This Link will be of some use? if you do decide to use any of the files you will need to rename the downloaded ogg file to exactly match the coresponding ov2 file as the ones I linked to are designed for use with a specific database from the same web site.
    If you are trying to get them to work with the TomTom database put them in the sounds folder, if they are custom POI style cameras in normal ov2 format put the files in to the North_America or Western Europe folder as applicable - Mike
    mikealder, Sep 12, 2009
    #2
    1. Advertisements
It takes just 2 minutes to sign up (and it's free!). Just click the sign up button to choose a username and then you can ask your own questions on the forum.
  1. Wobbly1
    camera warning voice....
    Wobbly1, Mar 31, 2007, in forum: System Configuration and Customization
    6
    877
    battom
    Apr 1, 2007
  2. john_d
    battery warning sound
    john_d, Sep 1, 2008, in forum: System Configuration and Customization
    0
    926
    john_d
    Sep 1, 2008
  3. zipforia
    Red Light Camera Warning Sound?
    zipforia, Sep 2, 2008, in forum: System Configuration and Customization
    5
    2,642
    Pedro2NR
    Nov 2, 2008
  4. Simon Gardner
    Alert and warning sound files
    Simon Gardner, Feb 27, 2010, in forum: System Configuration and Customization
    14
    7,359
  5. sneakersteve
    Traffic camera warning
    sneakersteve, May 24, 2010, in forum: TomTom Services
    1
    1,023
Loading...
