TomTom One New Edition will not power up unless it is plugged in
SE Pennsylvania
TomTom ONE New Edition
I have a TomTom One New Edition. It will not power up unless it is plugged in to the USB on my comptuer or car. I can plug it in for just a few seconds to turn it on, then unplug it and it will continue to run, but I can not power up without being plugged in.
Does anyone know of a fix for this?
Thanks in advance,
Joe
That sounds like the common problem where the units won't fire up after the sd card has been removed and re-inserted.
try a pin reset. There is a tiny hole on the bottom for this. use a toothpick or similar to reset the unit.
mine, when I remove and replace the sd card will not fire up without again removing and replacing the card each time I want to use it. after the pin reset it works fine.
garoutte07
