My tomtom go 720 will not charge up,
The green light comes on when it is connected to the wall, car or pc chargers but the device doesn't indicates that it is charging on the screen.
I have removed the battery and plugged it into another tomtom 730 which then charges the battery no problem, when I swap the ?now fully charged? battery back into the faulty device it runs fine until the battery is flat but still wont charge it up.
I have opened this unit up and can see no obvious loose or broken connections.
Think it might be a blown resistor or fuse or something like that although no sign of that on the pcb.
Anyone got a solution for this ?
Thanks in advance, any help is appreciated.
