Here is a guide. Study it carefully first, and make sure you have the few tools listed. The 510 and 910 are very similar - but no hard drive like the 910 - but there is a SD slot on the bottom of the 510. Take your SD out first.
http://www.unc.edu/~bmoc/tomtom/Tomt...g Manual.pdf
Good luck
The University must have pulled it down - I am sorry I did not save the file.
Search the forum and see if it has been posted anywhre else. That was the only place I had seen it.
I found it! Thanks so much GAW!
Where did you find it?? I have a 510 also with failing battery.
