To open your TomTom Go, first remove the front cover. After that you can remove four Torx T8 screws. You need a real Torx screwdriver to get the screws removed. Torx bits won't fit into the holes. You can get a matching screwdriver at Reichelt Electronics in Germany. The CK brand of tools in the UK are also good for this.
